メインコンテンツにスキップ
Appleの主要モデルである2021年のiPhoneは、9月24日に発売され、6.1インチの有機ELディスプレイ、デュアル12MPカメラシステムを搭載し、5色のカラーバリエーションが用意されています。iPhone 12の後継モデルです。
41回答 すべてを表示
Where is a good place to buy logic boards for cheap
I refurbish iPhones as a side thing and I need a place to buy logic boards as 90% of the phones I get are iCloud locked I have tried alie express but the logic boards are garbage and eBay seems overpriced most of the time is there any better place to buy iPhone logic boards
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi
Usually cheep logicboards aren’t really a thing but cheep devices are!
The boards can be found in devices that seem to be badly damaged ,eg cracked back and broken screen
Aslong as you ask if the device shows some signs of life(fully boots)and doesn’t have a iCloud you should be able to get a couple good boards if you are careful
You can also go down the route of micro soldering and board repairs,I do this and you can get some really nice boards out of it but microsoldering isn’t for everyone due to its difficulty
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
do u happen to know a place where i can buy very damaged phones i look for parts-only phones on ebay and I usually don't have much luck
さんによる
I can only confirm what @hellomacos is saying about parts phones. My usual go-to is job lot auctions (if I can get them for cheap), but I rarely buy those off eBay, because shipping + import duties + taxes makes it very expensive, even if the lot is cheap. I use Norwegian online marketplaces mostly.
Micro soldering / board level repairs can be tricky to get started with, but it’s an invaluable experience to have! You do need the right equipment though, an SMD rework station. You don’t need the super expensive stuff, but you don’t want the bottom dollar ones either. Mid range has done well for me, in my repairs. Just make sure the temperature control and airflow is accurate.
さんによる
@keith_themuscovyduck
As @geirandersen has said ,eBay is probably your best bet for faults devices
Local market places like Gum tree and Craig’s list can be used but I usually stay away from them if I want things that are definitely unlocked from iCloud as it’s hard to get a refund if things don’t go to plan:-)
さんによる
コメントを追加
回答を追加する
keith_themuscovyduck さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 70
