Why the phone charging is very slow
It take long time to charge and the network issues occurs offen
If you have charging and network issues you probably need to fit a new charging board. Sounds like moisture has entered the phone at the bottom if you have two issues in that area.
このアンサーは役に立ちましたか?
There was a update in mobile..because the phone charge slow I give you some tips and your problem was solve ..number 1 ..on the aeroplane mode while charging ..number 2...cheak memory or ram ..which app use high memory force stop the app...thanks..
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 16
今までの合計 163
