メインコンテンツにスキップ
S20シリーズのGalaxy Sスマートフォン。AI搭載トリプルカメラ、Infinity Oディスプレイ、LTE、5G機能付きWiFi 6を搭載。新色6色で展開。
33回答 すべてを表示
Samsung Galaxy S20 FE 5G UW in Cloud Red
I have a Samsung Galaxy S20 FE 5G UW in Cloud Red, Model number SM-G781V.
Is this part compatible with my phone (link to iFixit Shop below)?
Samsung Galaxy S20 5G (USA Verizon) Screen and Battery - this appears to be for model number SM-G981V. I can't find any info on whether this part is compatible with the phone model I have. Both are "Samsung Galaxy S20 FE 5G" phones, but I want to be sure before buying this part. I can't find info anywhere else...
Thanks
Samsung Galaxy S20 5G (USA Verizon) Screen and Battery - Genuineの画像
製品
$199.99
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @runlevelsix
Check what the battery model number is in your phone.
The battery shown in the ifixit replacement screen/battery link you posted has model number EB-BG981ABA
You are correct that it is confusing as this video for a Galaxy S20 FE 5G (no phone model variant number shown) shows that the battery model number is EB-BG781ABY which is also shown here for an SM-G781V model.
Here are some images of both the batteries showing their model numbers
(click on image to enlarge)
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks @jayeff for providing this context.
I haven't yet gotten up the courage to pop off the back of the phone, as I don't want to make the cracks any worse (it's already somewhat difficult to read the screen as-is. Is there a way to find the battery model number without physically opening the phone?
さんによる
@runlevelsix
Not totally sure but check the back of the phone to verify the model number of the phone. i.e. SM-G781xx or SM-G981xx. It should be printed on the back cover down near the bottom
The SM-G781V and the SM-G981V are different in physical size as well as their batteries have different capacities. Therefore the battery may be of a different size as well. Also there's no guarantee that the battery cable connector pinout is the same for each either
Depending on what the model number is for your phone, go with the battery that is meant for it.
It looks like the numbers ...781... and ...981... may indicate which battery belongs with which phone model as the number appears in both the battery model and the phone model. search online for "(insert model number i.e. sm-??????) battery" and check what battery model number is shown by the sellers.
Until you open it up, there's really no 100% way of knowing but usually using the phone model number when searching for parts is more accurate than using the phone model name.
さんによる
コメントを追加
回答を追加する
Jay Clark さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 185
