メインコンテンツにスキップ
9月20日にAppleが2019年に販売したiPhoneは5.8インチのOLED、3つのカメラがつき、バッテリー駆動時間が大幅に増加しました。iPhone XSの後継機です。
156回答 すべてを表示
iPhone 11 Pro NFC not working
Fixed an 11 Pro, changed full housing with an other 11 Pro, and sold it.. The only parts not changed are the motherboard, FaceID parts and the Taptic Engine... Everything worked while testing ( i couldn't test NFC ). Now the buyer says his NFC doesn't work. He broke the back glass so I will be charging him, where or wich one is the antenna for the NFC or what parts work together to make it work?
Please answer ASAP ( with pictures ), he wants me to repair his back glass so I will be doing a full housing repair ( keeping the same parts ), + new antenna('s) for NFC
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Why is my NFC not working on iPhone?
It’s possible that even if an Apple Pay-ready terminal will work with your phone, its NFC reader hasn’t properly detected Apple Pay. If you find that simply holding your phone up to the terminal doesn’t work, try selecting a card manually. To do this, go into the Wallet app, then select the card you want to use.
How do I turn on NFC on my iPhone XS?
First open the Settings app on your iPhone.
Then select the option “Control Center”.
Scroll down and tap the green plus button to the left of “NFC Tag Reader”.
Regards,
Will
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The NFC antenna feed is around the rear camera housing from top bezel to one of the screw posts for the logic board. Check if you forgot to transplant all the flex cables and the metal clips over to the new housing and assembled them correctly.
You supply pictures, I'm too lazy to upload pictures for a free answer.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
With the 11 Pro you have no antenna around the camera, its like only 3 antennas in the whole phone... What else could cause the problem?
さんによる
@vosjary Yes you have, you are not looking carefully enough.
さんによる
コメントを追加
回答を追加する
Jary vos さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 20
過去 30 日: 106
今までの合計 6,013
