メインコンテンツにスキップ
The backlight is not turning on when I use it.
My friend found a green one of these and when we tried to use it the backlight is not turning on. I dont know if it is because the screen light is burnt out, or the fact that it has been sitting in a kitchen drawer for 6 years.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
jaj there are two distinct possibilities. One, it is a failure on the backlight of the screen, which would be repaired by a screen replacement, iPod Nano 5th Generation ディスプレイの交換
Two, it is a failure of the circuit that powers the screen's backlight on the main circuit board. There are no schematics for this iPod (or any other iPod really). You could check for failed components and hope it's the backlight coil. Or you could replace the logic board (as above PITA) iPod Nano 第5世代のロジックボードアセンブリの交換 The failed backlight is actually a pretty common issue with the 5th Gen Nano.
iPod Nano 5th Generation ロジックボードアセンブリの画像
ガイド
難易度:
難しい
iPod Nano 5th Generation ディスプレイの画像
ガイド
難易度:
難しい
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Well the iPod works fine besides the screen, but there is some light green spots on the back. i also had the thought that it may be water damaged cause of the spots, and the fact that it was in a kitchen drawer near the sink area.
But thank you for helping.
さんによる
コメントを追加
I think you need to replace the LCD as that could be causing the problem
iPod nano (5th Gen) Color Display
Replace a malfunctioning or dim LCD display compatible with the fifth generation iPod nano.の画像
製品
$12.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
jaj さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 178
