How to turn on IC audio out of the board AN7523N.423
It's like a special audio player by itself, with or without button control
مصطفى أبو مريم here is the datasheet AN7523N Matsudhita. Pin 4 is the voltage in and pin 9 is the volume. Use the test circuit outlined on page 4 to check the IC.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 81
1件のコメント
مصطفى أبو مريم not quite sure what you are trying to do. Are you saying that you want this separate from the TV? what model is your TV? Explain further in detail what is going on and what your plans are.
oldturkey03 さんによる
