Camera shaking on samsung s 10 lite
Camera shaking sometimes when oprning camera on phone
If the phone has previously been dropped the camera could of sustained damage. Or the camera unit could be failing due to age. If possible try a new camera unit.
このアンサーは役に立ちましたか?
I also have this same problem, although my camera seems to have a slight damage to the frame, check that your camera is not bumped or something, the problem is something you can live with, just move it a little when it does, shake it until it is resolved, then take it to a specialized center so that they tell you more about this problem, which may be due to an external blow.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 5
過去 30 日: 24
今までの合計 461
