メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Being careful installed ifixit memory max we Ram Upgrade kit 2GB
I have a black screen after start up with the I fix it 2GB kit installed. I was very careful about static made sure to ground myself. When I put re install the 1 GB RAM originally installed (also an IFIXIT) (the data on the sticklers says exactly the same thing- 1GB DDR2 PC2-5300 667MHz except the PIN numbers. The original I took out says 204PIN and the ones I was sent say 200PIN.) Was I sent the wrong RAM? The chips look identical. Are they just miss marked? Is the one that works missed marked? What can I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Rod,
This is the repair forum; iFixit Store doesn't come here to answer questions. You need to send them an email at support@ifixit.com explaining your situation. They are very good about their warranties and will be happy to help you out with your questions.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Rod Mesa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 19
今までの合計 295
