メインコンテンツにスキップ
Microsoftの最新かつ超強力なゲームコンソールXbox One X(モデル番号1787)は2017年11月7日に発売されました。
159回答 すべてを表示
Xbox one X turns on and instantly off after thermal paste, pad, andssd
So basically my Xbox one x was overheating and turning off when I would launch red dead redemption 2. Also loading times for any games were really slow. Begin repair with changing in ssd from a laptop i don’t use anymore, Was greeted with the reset Xbox screen. I just waited for my thermal grizzly thermal pads to arrive. Did repair of thermal pads and paste and now it doesn’t work. Called repair shops and was told it could be a power supply issue. I bought a new power supply and the issue keeps happening. Thanks for your help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This is most likely a rail issue. I had the same situation brought into my shop about a month ago and had to replace some rails on it. This is not something I would recommend some one that is not experianced to try. It requires microsoldering gto replace and fix the issue.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hey I’m just wondering how much a repair shop would charge me to fix it and where could I go? Thanks for your answer as most likely it is something wrong on the motherboard as you said.
さんによる
@Ryan Shilts If you want to send it to me I can fix it, cost would be $175
さんによる
Sorry, my budget is like 80-120 on it. It’s already all opened up so idk if that makes it a bit cheaper.
さんによる
コメントを追加
回答を追加する
RyanS さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 336
