My right AirPod is not working
Hi, one AirPod no working is a common problem. Usually you should try to plug the case in and keep the AirPods in the case. Next I would try to disconnect them from your Bluetooth and try to reconnect while they are in the case. Then if they don’t work I would try going to your local tech co. To see if they can fix the problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 302
