メインコンテンツにスキップ
A14 Bionicプロセッサ、10.9インチのスクリーン、新しいデザイン、ボタン式のTouchIDを搭載したiPad Airタブレットです。2020年10月に発表。
36回答 すべてを表示
iPad screen wont turn on after power button replacement
Hello, i got this iPad from a friend. The iPad fell down and the power button got smashed in . It did power on when I put a cable in it but it went straight to recovery mode, I tried exiting recovery mode but it wasnt possible. After opening the iPad up I replaced thee power button but now the display will only light up for a few seconds and turn off again. I tried connecting it to my computer but the device is not recognized by iTunes neither 3uTools
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
hello there,
It seems that the fault is deeper than originally thought (which is rather normal for iPads, they are difficult devices to repair, especially in untrained hands). Remove the home button (disconnect it) and try to start the tablet again. The recovery mode clearly indicates that at least one of the devices on the motherboard has no contact or shorts its circuits to ground. The motherboard needs to be removed and inspected for all circumstances. However, the repair should not be expensive and rather short. Due to the broken Home button, you will probably lose Touch.ID functionality.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Apostolos Gkioni さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 80
