メインコンテンツにスキップ
Appleの最も大型で高額な2019年モデルが9月20日に発売されました。6.5" OLEDディスプレイ、トリプルレンズカメラシステムと、大きく改良されたバッテリーライフが特長です。iPhone XS Maxの継続モデルです。
Why won't my phone turn on after replacing screen?
I replaced the front screen, and it won't turn on. Could it be the charging port is damaged? Could it be the battery? Could it be the motherboard? I tested two screens, so I know it is not the screens.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Out of curiosity, was replacing the screen the first thing you did to try and diagnose the problem of not turning on, or was there another reason and the phone was turning on previously? How did it start; did anything change recently such as an IOS update, or any kind of damage like being dropped, getting wet, etc.?
As @tomchai mentioned, there are unfortunately a lot of different reasons why a phone doesn't turn on. Do you get any kind of indication such as a chime or vibration when you plug in a charger? You've tried different chargers and cables, right?
Go through this troubleshooting guide and see if anything there helps. If not, come on back and add the information on what you find to your question and we'll see what we can do to help.
iPhone Won't Turn On - iFixit
Good luck; let us know how it goes!
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Could be anything, you swap the parts to find out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
i change the screen, first time the new screen can turn on, but when I restarted it again, it cann't work, but I can sure the battery is ok, bez the scilent button is work well.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
B P さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 294
