メインコンテンツにスキップ
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
100回答 すべてを表示
Graphics Glitch while Gaming
Every time I try to game on it, It glitches out on the graphics and displays weird things and a Factory Reset only fixes it for a few days, It has been needing a battery replacement for years as it dies in under 2 hours but would that cause this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @xkienholz,
Does it do this if the charger is connected?
Try starting and using the tablet in safe mode and check if it happens.
If it doesn't then a downloaded app is the cause of the problem. The trick is to find out which one is the culprit.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I don't use it unplugged from the charger much anymore due to the battery practically being toast, Ill try it out but thank you!
さんによる
コメントを追加
回答を追加する
Xavier K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 66
