How do I clean and lubricate the main vacuum motor?
The main vacuume motor is getting noisy like it's bearings or bushings are getting dirty and squealing. Is there a breakdown that shows how to clean and lubricate it? Thank you
jasonrweaver I can’t find a service manual for your vacuum, only the instruction manual.
If you have a look at the device page, found here SharkIONFlex 2X, you will find guides on how to access the insides. Then you can determine what motor is in your model and if you are unsure how to proceed you can take high resolution pictures and update your question following this guide Adding images to existing questions
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 5
過去 30 日: 23
今までの合計 303
1件のコメント
jasonrweaver just to verify, your vacuum is a Shark IONFlex 2X? If so, take a look at the answer on this Question and see if it works for your vacuum as well.
oldturkey03 さんによる
