Black Conductive Pad under battery inside rear panel?
Where can you get these one side adhesive conductive copper / aluminium pads or tapes, do you know where ?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The copper helps dissipate heat, like a heatsink. When I work on iPod's, for example the touch 4g, I also add a dab of arctic silver paste since the paste is usually dried up.
You can find adhesive backed copper sheets, just cut to fit, google :
copper foil sheet
このアンサーは役に立ちましたか?
Thanks
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 284
7 件のコメント
Is this a necessary component?
Brad さんによる
I think so, because when the battery charges, it heats up. The pad takes the heat and via the body transfers it out of the case.....
Arnoud さんによる
do you mean on back of motherboard or on inside of rear case???
pollytintop さんによる
Inside of rear case behind battery....
Arnoud さんによる
Slide 30 in changing the rear case gives a good view.
Arnoud さんによる
2件以上のコメントを表示
