My Wifi is Greyed out, How could I fix it?
I have tried a reset and done everything WiFi works over Bluetooth using my iPhone but is very slow, It used to work just fine but now it doesnt it is a 16GB iPad Air 2.
This will not be an antenna issue. If the Wi-Fi is greyed out you defiantly have a board issue. You will need to check that the Wi-Fi chip is getting power, if it is you will need to re-ball or replace the chip. If it isn’t getting power you will need to find the faulty component that has failed. Microsoldering will be needed to fix this problem.
このアンサーは役に立ちましたか?
UPDATE: I just plugged it in and powered it on for the first time in a month, Wifi is back so I think it keeps getting overvolted or something like that.
It sounds like it could be an issue with the Wi-Fi Antenna. If you follow this guide to check the state of the antenna. I would attempt to reseat the antenna before attempting a replacement. Otherwise, it sounds like it could be an issue with the logic board.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 21
過去 30 日: 69
今までの合計 1,036
1件のコメント
Why hello Xavier. Trying to fix your iPad lol The wifi antenna might be bad.
Connor Steffenhagen さんによる
