Change / repair charging port from Mini USB to USB-C
I would like to know if this is possible to change to a USB -C charging port.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Red Salv possibly but not likely. The physical dimensions are different. The contacts will all be different and you would have to change the way your circuitry connects to it. The Mini USB and the USB-C really have not much in common.
The Mini USB has 5 pins from bottom Left to Right:
1 VBUS 5V POWER
2 D- DATA -
3 D+ DATA +
4 ID OTG IDENTIFICATION
5 GND GROUND
The USB-C has 24 pins from Top Right to Left and Bottom Right to Left:
A1 GND GROUND*
A2 TX1+ USB3.1 OR ALTERNATE MODE
A3 TX1- USB3.1 OR ALTERNATE MODE
A4 VBUS POWER*
A5 CC1 CC OR VCONN
A6 D+ DATA+ (USB 2.0)
A7 DA8 DATA- (USB 2.0)
A8 SBU1 ALTERNATE MODE
A9 VBUS POWER*
A10 RX2- USB3.1 OR ALTERNATE MODE
A11 RX2+ USB3.1 OR ALTERNATE MODE
A12 GND GROUND*
B1 GND GROUND*
B2 TX2+ USB3.1 OR ALTERNATE MODE
B3 TX2- USB3.1 OR ALTERNATE MODE
B4 VBUS POWER*
B5 CC2 CC OR VCONN
B6 D+ DATA+ (USB 2.0)
B7 D- DATA- (USB 2.0)
B8 SBU2 ALTERNATE MODE
B9 VBUS POWER*
B10 RX1- USB3.1 OR ALTERNATE MODE
B11 RX1+ USB3.1 OR ALTERNATE MODE
B12 GND GROUND*
As you can see there is a whole lot more going on in that connector ;-)
このアンサーは役に立ちましたか?
RIP time to move on and buy a tablet lol
@Red Salv yeah it would be quite a task ;-) Best of luck with your new tablet.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 30
