Hi
A good alternative to isopropyl alcohol is hand sanitiser as it has alcohol in it
If you use hand sanitiser make sure to clean the area with some deionised water afterwards because hand sanitiser has things that are good for our hands and things that are not so good for electronics so the deionised water will help take the bad bits away
As for the home button itself , I think that if it’s physically damaged you shouldn’t take it out of the screen assembly but if it’s fine I recommend taking it out of the assembly(unless you want to replace it)
Here’s the guide you will need for that
iPhone 6s Plus のホームボタンアセンブリの交換
Absolutely no pressure though,if you aren’t comfortable doing it only do what you think is right
If all the cleaning doesn’t work and you’ve tried reseating it,it could need replacing but you will loose Touch ID in the process unfortunately
Hopefully this helps
Any questions please ask
