メインコンテンツにスキップ
Appleのメインストリームとなる2020年iPhoneモデルは10月23日に発売されました。6.1インチOLEDディスプレイ、デュアル12MPカメラシステムと5色のカラーバリエーションがあります。iPhone 11の後継モデル。
170回答 すべてを表示
Are iPhones Still Water Resistant After Replacing Their Camera Glass?
I just replaced a cracked camera lens glass on my IPhone 12, will it still be water resistant after putting a new lens on? If not, is there anything I can do to make it water resistant again?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
With all due respect, I'm going to mostly disagree with Ben. Supposedly anything you do that affects any adhesive on the phone means it loses it waterproofing bona fides. However, done correctly, adhesive replacement can get the phone close to where it originally was with regard to water resistance.
I would personally be fine with the adhesive that comes with replacement camera lens glass, but if you want to up your feeling of security, you might consider placing the adhesive down, then run a very thin bead of silicone sealant around the outside edge of the adhesive. I'm talking about like the diameter of a pin, maybe a pencil lead, max. You definitely don't want enough in there that it could squeegee across the glue and get on the lens.
One thing to keep in mind is that with a crack in the glass it's definitely not waterproof! So anything you do to replace the glass is only going to help.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
No, as it says here: https://www.bing.com/search?q=Are+iPhone...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Unfortunately not, but i would recommend u to use camera lens protector that would make your phone a bit water resistant
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Max Leavitt さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 63
今までの合計 2,424
