Can Replacement battery warp charge?
If I replace the battery in my OnePlus 7 pro with the one you provide, will my phone still be able to warp charge?
I ordered a replacement battery in December... It works great - but charging speeds are 3x slower than before (although my phone shows that WARP charge is active)
このアンサーは役に立ちましたか?
I'm having a similar problem, however I ordered from witrigs.com
@stealmybones I think it might have to do with the latest Android 12 update and not the battery
Spirhit the batteries that iFixit sells are build to the same, if not better standards, as the original. There is no reason that your phone will continue to charge in exactly the same way as it did before. Like @strongbow already mentioned, if in doubt contact iFixit directly on here
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 21
今までの合計 307
1件のコメント
I think you need to email ifixit direct and ask.
[deleted] さんによる
