Tried everything but it still won’t turn on
So it does not turn on. Tried everything but it still won’t turn on, I tried cleaning it but it still looks like this
@evaneng since those were alkaline batteries the nickel on those contacts has been causticaly etched away. Use a long cotton applicator and mix some white vinegar and sterile water (about a 50/50 mix) and use the applicator to clean of more of the residue. It will not be shiney but will from now on continue to be rather dull looking. That is okay, for as long as you keep it from getting worse. After cleaning it with vinegar/water, use some high grade isopropyl alcohol to clean that off. Then apply some dielectric grease to those contracts. Nothing layered on just a fine coat will do.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 10
今までの合計 223
1件のコメント
@evaneng did you use IPA to clean it or something else as you might be left with (Possibly permanently) corroded contacts
Nick P さんによる
