メインコンテンツにスキップ
LG 27 Inch UltraFine 5K IPS Monitor with macOS Compatibility
Replacement part for thunderbolt connector
Does anybody know where I can get a replacement thunderbolt port for this? The one I have is broken off from the board and damaged internally so it needs to be replaced but can't find the part anywhere.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi
Unfortunately you can’t buy ports for this display so your only other option is to use one of the USB-C ports instead unless you have a donor board or can find a similar one
I suggest you watch this video as it goes into more detail
https://m.youtube.com/watch?v=zVmZby7Mug...
As they say in the video it’s quite common and you can’t buy replacement ports unfortunately
If you could find a pin diagram you might be able to find a similar port and try and solder it down to the right pins but I wouldn’t try it unless your comfortable with these sorts of complicated repairs
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Do a search on eBay. There are service providers who can professionally complete this repair for you if you send them your motherboard from the monitor. The most common price I’ve seen for this repair is $150.
さんによる
コメントを追加
回答を追加する
Darragh さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 19
過去 30 日: 115
今までの合計 2,889
