メインコンテンツにスキップ
The DJI Osmo Mobile is a phone camera stabilizer that enhances users ability to take videos and pictures. It features a rotation speed of 120 degrees per second and connectivity via Bluetooth with app support. Model numbers are identified by ZM01 and OM150.
4回答 すべてを表示
How can I make my own charging cable?
I have a DJI Osmo mobile. There was a USB to 3.5mm cable for charging this device. Unfortunately, I lost the cable. I can't find the cable anywhere in my country. Also, they no longer sell this cable and I have seen people complaining about this cable in multiple forums. I have enough understanding of electronics to make one. But I need the USB to 3.5mm connection configuration. Where can I get this one?
(I can open the Osmo mobile and find the pin configuration from the circuit board But I don't wanna risk anything by opening it.)
Can anyone please help me find the pin configuration of this particular cable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi
Unfortunately I don’t recommend make your own charger unless you have a lot of experience as you need precise soldering skills,if two of the solder connections were to short together you could damage your device
However
Here’s a link to one thats already made for you!
https://a.aliexpress.com/_msMuhbA
If it isn’t available in your country please let me know and il find another one but this one should be ok
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Emroze Islam さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 19
今までの合計 59
