メインコンテンツにスキップ
Released on September 18th, 2020, the Samsung Galaxy Tab S7+ (SM-T970) is the larger, more powerful version of the Tab S7. It features a 12.4-inch Super AMOLED display and a Qualcomm Snapdragon 865 processor.
Similarities to Samsung Galaxy Tab S7
I have Galaxy Tab S7 (not the + or wifi-version). I wasn't able to find any instructions on the Version I have so I wanted to ask if the repair of the charging port is the same as on the Galaxy Tab S7+.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@ollj99 take a look and see if you can identify it by model. Should be a SM-T875 (LTE) or a SM-T876B (LTE/5G)
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi Oliver,
I found a video teardown that shows the removal of the charging port as part of the process.
Samsung Galaxy Tab S7 11" SM-T870 / SM-T875 Full Disassembly Teardown Guide. - YouTube
Follow the guide through the removal of the screen to about 2:22 into the video, then skip the section on removing the midframe and jump to about 3:35 where it shows the removal of the charging port.
Comparing the video to the Tab S7+, it does appear there are significant differences in the way they come apart, most notably in the fact that the S7+'s midframe covers the charging port so it has to be removed, while the S7 doesn't. On the S7+, the guide shows unplugging the LCD from the motherboard, while the S7 video shows that you can unplug the display from the LCD itself.
Hope this helps; let us know how it goes!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Oliver Jeske さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 18
今までの合計 436
