メインコンテンツにスキップ
Bose's consumer range of active noise-cancelling headphones are called "QuietComfort".
21回答 すべてを表示
qc25 headphone wire jack does not connect
Hi, I have a qc25 headphones and yesterday my audio cable no longer connects to the earcup and stay connected, I notice the small piece that it is supposed to connect to, is lose and seemed to have been "pushed" out of it's plastic holder.
Is there any way to fix this?
thanks
amit
Hi, the part that connects to the end of the audio cable seems to have been disconnected from the plastic piece that holds it together to the ear cup, allowing the male connector to the female connector. I can hear it rattling around, but I can not take everything apart to reach it. Seems to need a special tool to connect it while screwing the plastic piece.
see images; sorry it is very hard to take a picture of it, as it is internal and hard to get the light in there.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@amitbarkan73 if you are referring to the headphone jack then it is time to take your headphones apart to investigate what has come off. Use these guides to work on your Bose. Bose QuietComfort 25
Post plenty of pictures of what you encounter with your QUESTION so we can see what you see. I've replaced my jack with a permanently connected audio cable. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
updated images and explanation. thank you
さんによる
コメントを追加
回答を追加する
AMIT BARKAN さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 332
