メインコンテンツにスキップ
Guides and repair information for vehicles made by SEAT, which produces small economical cars for the European market.
17回答 すべてを表示
Engine noise from 2011 Seat Leon
I have a 2011 1.6 Litre Seat Leon Diesel. The engine has been louder than usual and there is a vibrating when sitting in the car. The vibrating is worse when the clutch is depressed. Does anyone know what could cause this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@johndoe177 this "The vibrating is worse when the clutch is depressed" could be a bad bearing or a worn pressure plate. Check your clutch a bit better and see if the noise sounds more like a grinding coming from the clutch area. Of course it could also be a vacuum leak as well as 100 other things that may cause your engine to develop a vibration. Consider having the OBD scanned to see if it throws a code.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
John doe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 33
今までの合計 583
