メインコンテンツにスキップ
Electric trimmer for grass edges and confined spaces. Also known as a Strimmer.
1回答 すべてを表示
Motor slows down and stops
The motor gets hot and stops in a few seconds. The commutator has burn marks and beads of metal(?) alongside it. I have measured the resistances between each adjacent segment on the commutator, they are all between 3.5 and 4 ohm each. The brushes seem to be OK. Does the insulation break down? I tried cleaning it up but it goes bad the same way when turned on for a few seconds.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@alanport yes you will need a new one. the wires are insulation coated. It gets hot and melts and shortens out. There are places that rewind those but the cost will most likely exceed the cost of a new motor
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thanks, no surprise really.
さんによる
コメントを追加
回答を追加する
Alan Thurbon さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 22
今までの合計 89
