メインコンテンツにスキップ
After switching on device all three temperature indicators started bli
After switching on device it heats up while and all the temperature indicators started blinking.
Still straightener keeps on heating, but temperature level couldn't be identified as all three indicators are blinking
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Your Steampod flashes due to a component failure. In the majority of cases, it will be a failure from one of these elements:
  • the resistance of the plates
  • the electronic card
  • the thermostat
  • Before moving on to hardware repairs, remember to check that there is enough water in the tank flashing Steampod straightener. Indeed, if it lacks water, it may not be able to reach the requested temperature and therefore it signals you by flashing. Also check that the hair straightener is not in energy saving mode. Indeed, the device goes into standby after 1 hour without manipulation. If you try to turn it on without having reset it, then it may start blinking and not turn on. To reset the Steampod, you just have to long press the on/off button.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Muhammadbilal Pathan さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 74
今までの合計 258
