need help with know which board is the inverter board
which board is the inverter board on the Vizio E55-E2 s/n # LWZ2VIKT4505529 i need to replace it but every time I google it I get the power board
edit note: so I basically did the test with the flash light and results say it’s the inverter board and didn’t see anything with the light strips is that hard to replace ?
New pictures more notes
The only test I did was the flash light test. The tv image went super dark after a min of being on and the image would only come back after the tv was turned off for a while but the image would go back to dark after a few min. Anyways, when it did go dark I would flash the light at it and could see the image better
6 件のコメント
Michael Rey post one picture of all the boards and all the interconnect cables. Essentially what you look at when you remove the back cover.
oldturkey03 さんによる
Gotcha !! I got a few more
Michael Rey さんによる
@Michael Rey thanks for the images. Yes, your “inverter” is part of the mainboard.
oldturkey03 さんによる
@oldturkey03 so the main board is the power board, the brown board ? Also would you recommend switch bothering with the light strips ?
Michael Rey さんによる
Also THANK YOU SO MUCH! @oldturkey03
Michael Rey さんによる
1以上のコメントを表示
