メインコンテンツにスキップ
DUALSHOCKシリーズの後継機種である初代Sony PlayStation 5 DualSenseコントローラーの修理ガイド、分解、トラブルシューティング情報。 型番はCFI-ZCT1W、マザーボードの型番はBDM-010です。
What would cause a bumper button to not work
I have a PS5 Dualsense remote with a suddenly non-functioning R1 button.
  • No physical damage to the remote from dropping/excessive force has been exerted
  • No water damage
  • The black plastic part of the button is in the correct position. Removing to access the silicone part of the bumper button and pressing with a pry tool/screw driver does not work
  • R2, L1 and L2, as well as all other functionality is perfect
  • The remote is a v1 remote
I've tried disassembling the remote and investigating, nothing out of the ordinary to report and I'm at wits end. Any guidance would be appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
Ended up being a microtear in the ribbon cable through some of the middle connections, which obviously affects the R1 button in particular.
Easy enough to replace, but I can imagine that with the design of the right ribbon cable being more exposed it could potentially lead to more issues over the left one
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Had to buy a new L1 bumber it goes in normally & even works but won’t stay in the holder whatsoever. Falls right out when I turn controller upside down or tip it over confused tried everything what could it be ?
さんによる
コメントを追加
How do you fix the micro tear
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Replacement ribbon cables can be found on Amazon. Watch for the generation controller you have though as apparently there are several and some use slightly different cables.
さんによる
コメントを追加
My L1 has the issue even after replacing ribbon cable with new one iam still facing the same issue don't know of it's hardware to software issue
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jarod Kurland さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 23
過去 30 日: 83
今までの合計 5,761
