メインコンテンツにスキップ
MBP not turning on but sleep light is on
I was trying to watch a movie in my '06 MBP and suddenly I got a message "Disk can not be read" (movie was on a flash drive), then the screen turned off and the keyboard remained on. I decided to plug off the computer since it doesn't have a working battery (it works connected to its original 85w charger) after doing so, every time I try to turn it on the sleep light goes on and the DVD drive spins for a brief moment, but it does not do anything else (the screen is pitch black).
I've tried resetting SMC to no results, I can't try resetting PRAM because the R letter of the keyboard does not work.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Just found the solution, I replaced the RAM module with a 1GB one, then booted the computer and it turned on! After that, I cleaned the original RAM module (2gigs) with rubber, put it back and it is working!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Topo Ceni さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 134
