メインコンテンツにスキップ
モデル番号A1288/ 8, 16もしくは32 GB容量
451回答 すべてを表示
WIll the LCD work without Top Glass and Digitizer?
I replaced a cracked glass on my Ipod touch 3rd g. I bought frame glass and digitizer( probably too cheap), easy to replace after watching videos, it's not working and I tried testing if I accidentaly damaged the LCD and my question is this: does the LCD supposed to work without top glass and digitizer or will not respond without them???
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
最も参考になった回答
sotiriob, you say in your question "does the LCD supposed to work without top glass and digitizer or will not respond without them???" and Carpenter940 is absolutely right, you will/should see everything, but your touch will NOT work unless your have the digitizer connected. Touching the LCD without the digitizer will not do anything.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Exactly the answer I needed the LCD is doing nothing because the glass and digitizer I've replaced it's not the right one for this ipod... where should I get the right one if you guys would know?? so far I've tried two cheap one via EBAY and not working of course. thanks for all your help!
さんによる
If you want quality with great customer support, get it from here iPod touch (Gen 2) Front Panel Assembly otherwise I'd try alibaba.com or tvc-mall.com. I bought from those companies before and did not have any problems with it.
さんによる
コメントを追加
LCD will work without digitizer. You should see something.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Yes.... it's right the display goes on , but my question is why it doesn't work when I touch it, meaning when I try to slide to open themani page or the password page it wont do anything.... is it something completely wrong with the ipod?
さんによる
I read that you have a 3g. I know on the 2g some Ipods are finicky with the digitizer. They need an original apple brand or else they wont work. Luckily, I was able to buy a cheap China one and it worked.
Try re-attaching digitizer or cleaning contact points. Also, make sure you didn't tear the cable when installing. If you still have your old digitizer and it worked try that
さんによる
コメントを追加
yes, but you may have to restore the ipod afterwards if you actually boot it with the digitizer off. this knowledge unfortunately is from personal experience by accidentally turning my ipod on while cleaning the dust from between the screen and digitizer, i had no slider on lockscreen and when i put the digitizer back on (after figuring out how to turn it back off) the screen was responsive but the ipod would take an extremely long time to do the simplest of tasks (like 20secs to unlock) i restored it and it was fine after that but was a pain in the butt for something as simple as booting it without a digitizer connected
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Your iPod probably won't work unless you have the digitizer or the faceplate on. If the faceplate cracked or broke, you still have the digitzer which can control the touch screen, but your iPod's screen will no longer be protected because the faceplate was the outer protection of the screen. But your iPod will still work. Now if the digitizer and the faceplate broke, now you need to panic. but you can always go to an Apple store and they might repair it for you. Don't worry, as long as you have your digitizer, your okay. :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sotiriob さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 38
今までの合計 22,961
