メインコンテンツにスキップ
2020年5月発売の13インチMacBook ProはクワッドコアIntl 第10世代Core i5/i7プロセッサ搭載でIntl Iris Plus グラフィックス搭載(モデル番号 A2251/EMC 3348、4つのThunderbolt 3ポート)
71回答 すべてを表示
MacBook erased, but won't boot after xartutil --erase-all comm
After erasing the MacBook, I also wanted to erase the Touch Bar. However, after the command
xartutil -erase-all
My MacBook does not start anymore. The screen no longer lights up or turns on. Tried all reset commands. How do I get him to work again?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You'll need access to another TB Mack system to run the Apple Configurator 2 app to try to re-install the system firmware. Here's more on it How to install Apple Configurator 2 for macOS
Basically, putting the system into DFU mode
Try running both Revive and Restore options
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Thanks for the answer. When i erased the macbook it worked fine. but after the command xartutil-erase it is complete dead and i also get i not in DFU mode. is ther another solution maybe....?
さんによる
@maxgeertsen - Your system uses firmware which is stored on the drive which you erased! What made sense in older systems creates issues with the newer models.
The other option is visiting an Apple Store who have a tech that can reload the firmware partition.
さんによる
Hello, I also deleted the touch bar and I have the same problem as Max@geertsen.nl, did anyone manage to restart their macbook after turning it off? Thanks
さんによる
@rorovd83 - As I explained you need a second system to run the Apple Configurator 2 tool.
さんによる
コメントを追加
回答を追加する
Max@geertsen.nl さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 69
今までの合計 789
