メインコンテンツにスキップ
Xbox Series Sは、マイクロソフトの最新のスモールフォームファクタ、デジタル専用ゲーム機です。Xbox Series Sは、よりパワフルなXbox Series Xと共に2020年11月10日に発売されました。
Xbox Series S keeps shutting off
My Xbox series s keeps turning off at random moments. It can be after an hour of gaming, or literally 2 seconds after I turn it on. I’ve tried plugging it into different outlets, factory resetting, leaving it unplugged for an hour, still no luck. Not sure if I should buy another power cord, but it doesn’t look physically damaged. Not sure what I should do at this point. Please help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
6 件のコメント:
Cheapest and easiest thing to do is a power cord. I would try that first.
さんによる
Very good point
さんによる
Thanks for the suggestion. I have one being delivered today. I'll provide an update as to whether the issue continues or not.
さんによる
Good luck. Hope it works
さんによる
Yea, the cord wasn’t the issue. The only thing I can think of before getting it repaired/getting another Xbox is trying a cooling fan? The Xbox doesn’t feel hot but maybe it’s overheating.
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
It could be a power cord issue, but it could also be the power supply that you need to replace. It could also be the motherboard, which I doubt. If you decide to get a new power supply, be careful with the broken one. Do not open the old power supply. Does your Xbox have good ventilation? Here's the article from xbox.com
https://support.xbox.com/en-US/help/hard...
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
I came across something that I've only been able to test for one day, but I think it may have fixed my issue. My video display was set to automatic. Once I switched it to manual (HDMI), I was able to change my Xbox from 120Hz to 60Hz. Although the picture seems wide beyond the borders of my tv, I haven't had any more issues with the Xbox shutting off.
I'm not sure exactly how this fixed the issue, but it's been working ever since.
さんによる
@gssiler7 That's good. well hope you find out how you fixed it.
さんによる
It turns out that the issues still persist. I'm getting a diagnostics test run on it today. Just debating on if I'll pay a bunch of money for someone to fix it, or order parts and fix the issue myself.
さんによる
Do you get a overheating message before it shuts off?
さんによる
No. I’ve never gotten that message. I took it to ubreakifix and they’ll have some answers by Thursday. He said it could be the fan, power supply, or motherboard (if the motherboard, there’s nothing that they can do about it).
さんによる
3件以上のコメントを表示
コメントを追加
It just overhead nd the fan will turn on all way up
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gavante さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 18
過去 30 日: 86
今までの合計 4,711
