メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1136/30、60、80GBハードドライブ/ブラックまたは白のプラスチックフロント
constant restore loop after logic board replace
after replacing the logic board the iPod boots to a white screen asking you to connect to iTunes and Restore. iTunes fails during the restore due to error 1416/1415. This happens in both Windows and Mac OS X (tried tiger, leopard and snow).
When I look at the partition via pdisk, it says that there is no valid block 1 on the device.
Do I have a bad hard disk or is there another fix I'm missing.
Richard
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Try unplugging all USB devices other than the iPod cable, keyboard and mouse. Sometimes when trying to do a restore other USB devices can interfere in the process. I that doesn't work then you should try to take it apart and replug all of the cables to make sure they all have a good connection. If that still doesn't work then it probably has a hardware problem. That would mean either the logic board, hard drive or possibly even the hard drive cable.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Richard さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,775
