メインコンテンツにスキップ
2015年10月26日にリリースされた第4世代のSurface Proタブレット。
Screen flicker/shaking after changing display
I replaced the display on an SP4 I have, and everything seemed fine. However, after now replacing the SSD drive I a running into an issue where after using the device for about an hour or so the screen starts "flickering", and shaking around.
I have read all about "flickergate" and the many suggestions on potential fixes with no change. (When the issue starts if I shut down and go into UEFI mode the issue remains).
Is it possible the fan is not starting up? Is there an easy way to tell without opening things up again?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Well, I dont know if there is anything wrong with the fan - but def. confirmed its a heat issue. While watching a movie yesterday the screen started doing that thing - I used an upside down can of compressed air on the back of the device and the picture returned to noral. For a little while
I guess I will take it apart and check the fan - just dont want to go through all of that again
さんによる
コメントを追加
1 件の回答
HI.
I had the problem of screen flicker when I replaced the screen on my tablet pro 4 with the spare part sold by ifixit. I finally had to opt for the Surface Pro 5 screen, which is compatible. You'll find my commentary on this subject here, which you might find useful:
https://fr.ifixit.com/R%C3%A9ponses/Affi...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Justin Greywolf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 301
