メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
I replaced the battery on my old 5s and now it will not charge.
I replaced the battery on this old phone and now it will not charge. The phone acknowledges that the cord is connected and I get the little lightning bolt in top right corner saying it’s charging, but the percentage does not go back up. Multiple apple cords and chargers as well. Also, taken phone back apart and checked for bad connections and bent pins but everything was perfect. Reassembled and still the same thing.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
You likely have a defective battery. See if you can get a replacement from the manufacturer or buy another from Ifixit.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
The first thing to check would probably be the battery itself. Where did you buy it, and what brand is it? Do a google search and see if others have had problems with that brand. Unfortunately, some off-brands are just junk and not worth a purchase. Or you could have just gotten a bad battery. Try to contact your seller and see if you can arrange a replacement. If a different battery does the same thing it might be a damaged port, but I believe that it would have been doing this same thing before your repair if that was the case.
I hope you can get a new battery and a quick swap is all you need.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
As others have said. This could definitely be a bad battery. If you still have it, see if the old battery exhibits the same behavior.
If not, then bad battery. If it does, this may be pry damage on the logic board. On the iPhone 5S and SE first generation there are some tiny little components next to the battery connector which are responsible for the transmission of battery data that commonly get knocked off during replacements. So power management components wouldn’t have anyway of knowing how charged the battery is. So even if it IS charging, the phone would have no idea.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Kip さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 43
