メインコンテンツにスキップ
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
150回答 すべてを表示
What is restarting the bootloader done for, in Fast boot mode?
It powers on but doesn't get beyond the power on loading screen. I get it powered off then hold power and both volumes until the screen shows a green bot lying down with the stomach door open. At the bottom left of the screen I see
product name - grouper
variant - grouper
HW version - ER5
bootloader version - 4.23
baseband version - n/a
Serial # - 015d4906bb381410
signing - not defined yet
LOCK STATE - LOCKED
At the upper right corner I see START and arrows up and down. I push the volume down button to scroll through the options of RESTART BOOTLOADER, Recovery mode, Power off.
I tried the Recovery mode option and I only see the word GOOGLE with no further activity.
What is restart BOOTLOADER?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
As the name implies, it'll restart the bootloader. To the get a better understanding of what lies behind Android's bootloader menu you might want to check out this tutorial.
Seems like other users had the same problem, in this page are listed some methods that could work, how I'd go about it all depends on whether you need to keep the data or you're just good with making your tablet work again. Wiping Cache and tapping the back of the device are both quite safe and you can simply give them a try. The other 2 methods listed are more destructive, in the sense that though Wug's Toolkit and factory resetting may solve the issue, all unsaved data will be lost if not backed up before-hand (I checked the FAQ and the Toolkit does actually have a "No Wipe Mode" option, but I'm not sure it can apply here).
For any other questions feel free to ask, and let us know if any of these methods worked for you
Nexus 7の画像
ガイド
Asus Google Nexus 7 / 2012 - factory reset
難易度:
とても簡単
5 minutes
Android Phoneの画像
ガイド
Bootloader, Recovery, and the joy of unlocking
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Jennifer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 25
今までの合計 303
