My cpu is overclocking
the cpu fails every friday
この質問は役に立ちましたか?
Hi
When you say fails do you mean over heat or a 100% fail
Let’s see what your cpu is doing by installing intel power gadget
Here’s a link to it
https://www.intel.com/content/www/us/en/...
Also can you add some images of what it’s saying using this amazing guide
Also did you try a pram and smc reset?
Here’s a link for it
https://discussions.apple.com/docs/DOC-3...
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
@hellomacos its a 100% fail, i downloaded the app and my processor is on a 42% all i can say the cpu is not looking good it might need replaced. My processor is a Intel core i5
Hey Bill
Not entirely sure your concern but here is some tips that could help.
Best of luck!
このアンサーは役に立ちましたか?
Hi james, i downloaded turboboost switcher and it wasnt enabled, the mac runs fine until a certain time. I think this is because this macbook has been tampered with because it was owned by someonr else before. (I bought of cex)
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 379
1件のコメント
@johnbill444 - I think you really have a different issue!
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see iFixitでの質問に画像を追加する方法
You might also want to install this great app as well TG Pro I think you'll see the fan is running hard and you might see the CPU running hot. Post a snapshot of the main window, make sure you capture all of the sensors as it exceeds the windows size.
You could also see if running the onboard diagnostics gives you any errors. Restart your system and press the D key. Let us know what the errors are.
DanJ さんによる
