メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Screen turning black from the bottom
I did a battery replacement and I did something I probably shouldn’t and didn’t need to do, I removed the screen. Before, this phone just had a water damaged (but working) screen and a spicy pillow. Now after power cycling, repositioning the connector, and hard resetting, it still shows this. It’s different every time, but every time it turns on from boot, everything is fine until the apple logo turns greyish. The screen starts turning black from the bottom and spreads throughout the screen slowly as i use it. It also has a similar effect to burn in.
Is this circuitry damage or did the battery expanding inside destroy the screen?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@erse double check your complete work. From what you said the prior battery had expanded so yes, that could be an issue that will require a new screen. the only other thing I wonder about is how you handle the water damage. Double check your connector for bend pins on both the board and the cable connector. After that, I recommend you get a new display and change yours. If nothing else it will give you a known-well starting point for further troubleshooting.
iPhone 5 LCDとデジタイザの交換
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I took my time and i noticed some of the foam on top of the connectors fell off and parts landed in between the connectors. I fixed that and it is mostly working now. Although there are very faint white vertical lines that get brighter on darker colors, but I think that’s just a display problem. After seeing the display turn on for the first time in ages, I noticed the resolution seemed pretty bad, not as I remembered. Maybe thats cause displays have gotten so good now, but there is a big difference compared to the 5s.
One more question, is it bad if the battery is all the way to the left? Not sure how much space is needed because i heard batteries expand. It’s practically touching the whole left side with a big gap on the top and right side.
さんによる
@erse as long as it does have room to do some expansion, you will be okay. Different story if it is all the way around tight.
さんによる
コメントを追加
回答を追加する
Alex Ren さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 30
