メインコンテンツにスキップ
9月20日に発売された、Appleのメインストリームとなる2019年iPhoneモデルには、6.1インチLCDタッチスクリーン、デュアルカメラが搭載されており、6色から選べるカラーセレクションです。iPhone XRの継続モデル。
482回答 すべてを表示
iPhone not charging after installing replacement battery.
Hey all. I just installed the ifixit replacement battery into my iPhone 11. It now starts up fine and everything seems to work just fine, except for the battery.
Of course, I lost all the battery health information, but I expected that. It's also showing 0% charge, and will restart randomly after a couple minutes. I have it plugged into a charger, but it does not show a charging symbol. It does make the sound and small vibration when it's plugged in though.
I tried force restarting it several times as well, it did nothing. Did I get a bad battery?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
If your old battery was still charging you will need to open the phone back up and check the battery connector is seated properly also check that you haven’t nudged or knocked off any of the small components around the connector. After reseating the battery connector if it still will not charge you will need to try another replacement battery as the one you purchased is probably faulty.
 If you’re old battery stopped charging and showing percentage the same as the replacement one you will have a board issue that will require a reputable repairer to diagnose.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
The old battery is charging fine and ok but i don't know what happened with the new one
さんによる
It just happened to me. what I did was to open again the phone, disconnect and reconnect the battery connector and it worked.
さんによる
コメントを追加
回答を追加する
Hayden Shaw さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 38
過去 30 日: 153
今までの合計 3,273
