メインコンテンツにスキップ
Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
17回答 すべてを表示
Acer Nitro 5 AN515-43 booting problem.
Good day, please help me with my laptop, when I press power button the light indicator turns blue then turns off after few seconds, the screen doesnt show anything and the fans are not spinning and also the hdd, but the motherboard has power because when I put external keyboard in laptop, the keyboard lights up. But when I insert it to other usb port, it doesnt work, only the one usb port is working. Also I can charge the laptop but it just dont boot up and doesnt show anything. Please help me, thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Disconnect the battery and see if it runs on just the charger. If that works the battery may need replacement.
さんによる
@aactech Still it doesnt turn on, only the light indicator and after few seconds it turns off.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Something may be shorting the motherboard or a setting in the BIOS may have become corrupted.
Try disconnecting, taking out the battery and discharging all power in system by holding down power button for 30 seconds.
Reset the CMOS by disconnecting the coin battery.
The round, coin sized, black covered object with 2 wires (black and red) running to motherboard connector to the right under the main battery. Video may help:
https://www.youtube.com/watch?v=-UIPoU-8...
This will set all settings in the BIOS to factory defaults.
Also disconnect the hard drive and Wi-Fi in case one of these is causing the problem.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
@aactech I followed all your instructions sir but still it doesnt work, nothing changes in my laptop's condition.
I have a video link that describes my problem;
This first link describe the problem that I posted: https://drive.google.com/file/d/1JsrW8mB...
This second link describe the usb port has power even the laptop is off: https://drive.google.com/file/d/1E9DYETO...
Thank you for taking time with my problem sir.
さんによる
Hi @Tech guy
Have you tried connecting to an external monitor or TV to see if any video appears?
さんによる
@aactech I have not tried it yet since I dont have connector that I can use to connect it to external monitor, I will get back here as soon as I can test it.
さんによる
@aactech I have tested connecting to external monitor but unfortunately nothing is shown, it does not detect anything.
さんによる
@aactech By using the super macro feature of my mobile phone's camera, I found something like spilled liquid in the motherboard, I also found it present in between the pins of some chips in motherboard, could this be the culprit? I dont know why it is there, can I fix my mobo if I clean it? Do you have any suggestions regarding what to use in cleaning?
These are the images I took:
https://drive.google.com/file/d/1SlaY_Rv...
https://drive.google.com/file/d/1nHU6OQ-...
https://drive.google.com/file/d/1EbLPAVj...
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
Tech guy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 41
今までの合計 3,173
