メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1502回答 すべてを表示
Which Parts Exactly Do I Need to Order?
I have a 3GS with a visible hairline crack, and pixels dying in a wide horizontal line at the bottom of the screen.
Which part or parts should I order to repair both of these problems?
Does the "Display" include both the glass and what one would think of as a traditional display? Or are there two parts needed.
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
5件の回答
ベストアンサー
Ifixit has the parts you need for this repair.
[リンクされた製品が存在しない、もしくは無効: IF142-002]
NOTE; I just noticed that it is currently out of stock. But, you have an option to have them email you when the part comes in, I'm pretty sure it wont be long before they get it in.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I was worried it was the assembly. Guess I'll wait until June (as long as I can read the screen that long) to see if a new phone is released as the repair is the same cost as a new one.
Thanks!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No problem. Good luck!
さんによる
コメントを追加
Scott, would you be interested in selling it?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sorry, it's my only phone - and while the screen is mucked up it still works. So, I intend to keep it until a new model is released.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You need an LCD and Digitizer. My understanding is the glass is cracked and the gray lines you see are actually damage to the LCD screen underneath.
You can buy and entire midframe assembly with glass, LCD, home button, proximity sensor assembly all pre-assembled on eBay and this would be the best route if you are not mechanically inclined. However you may not be getting "orignal" Apple parts, so read carefully. Always look for OEM or original quality assemblies if available, there are a bunch of garbage 3rd party parts out there so beware of imitators, calling it junk is an understatement! Also, not all that say "OEM" actually are. Look for words like "Genuine" or "Original" in the listing and the Apple name (properly spelled too, APPIE doesn't count!) will be on some components.
If you buy just the digitizer (with 3M adhesive) and LCD this will be least expensive route to repair (probably have about $75 invested for both "genuine Apple quality" on eBay), but you'll be in for some skilled disassembly to get the old digitizer from the midframe without damaging the rubber dust seal or other components of the midframe. FYI... I have an iPhone repair shop in Columbus OH. and I charge $150 parts and labor to replace both LCD and Digitizer on the 3Gs with 100% genuine Apple parts. Yes 1/2 that cost is labor, it will take time and patience to do it right!
Again I can't stress enough the importance of "original" or "true OEM" high quality parts. I have a over 3 years experience now and have worked with many vendors learning the hard way about variances in parts quality. Your digitizer should bear the Apple name on the flex cable. Look closely at photos before buying anything from eBay and stick with US sellers to avoid long shipping times and return hassles if you receive damaged goods.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Scott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 12
今までの合計 1,441
