メインコンテンツにスキップ
2021年に向けたAppleの最上位スマートフォン。9月24日に発売された「iPhone 13 Pro Max」は、6.7インチのProMotion OLEDディスプレイ、新しいトリプルリアカメラシステム、5G接続を搭載しています。iPhone 12 Pro Maxの後継機種。
How do I replace the glass protecting the camera?
Somehow my glass lens cracked protecting my camera on my phone and chip another, I how would I go about to fixing this dilemma ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
Hi Olav,
The rear camera lens covers really aren't all that tricky. They're just circles of glass held in with adhesive, so replacing them is basically a matter of picking the broken glass out, removing the adhesive and sticking down a new lens. Really, all you have to worry about is leaving glass chips inside, so clean it out well and don't get fingerprints on the camera lens itself, and of course be careful to not scratch the lens either. I've done it on my Pixel 2, and it's exactly the same for the iPhones.
There's a video guide on YouTube for your phone, but really any guide will work.
How to Replace Camera Lens iPhone 13 Pro Max / 12 Pro Max - YouTube
The parts are easy to get too; I ran across them with a cursory search on Amazon, eBay and AliExpress all, and they're not expensive. Here's one as an example.
Amazon.com: ASDAWN Back Rear Camera Lens Glass Replacement for iPhone 13 Pro Max and 13 Pro Camera Glass Lens Replacement with Pre-Installed Adhesive + Repair Tool Kit + Installation Manual : Cell Phones & Accessories
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
I just made a failed attempt to replace one of the glass lens covers on my iPhone 13 Pro. Overheated the lens itself and it fogged instantly. Too many people out there making this fix sound easy. Still couldn’t even pry off the lens glass anyway. What a waste. The real question is why can’t apple design something that doesn’t have big delicate glass lenses extending so far out of the %#*@ phone? Really miss my XR right now.
さんによる
Yes, exactly. Why ask why, right? The covers should just screw off. How difficult would that be? I hate Apple
さんによる
コメントを追加
replacing the camera isn't quite as easy as expressed by many people on the internet. sure, you can pick the glass out of the rear camera lens bezel BUT, if you go the rout of not removing the screen and removing the camera first there are risks that you need to be aware of. If while removing the glass you get glass shard fragments in the focal motor, it can render the camera useless. the proper way of doing this is to remove the screen and then removing the camera and pushing the glass out of the back of the frame. this eliminates any risk of getting glass into the focal motor and getting glass shard fragments on the lens coating.
このアンサーは役に立ちましたか?
スコア 3
3 件のコメント:
Jarius, you are absolutely correct. For a simple crack, it is generally easy, but if the lens is shattered with many small fragments then yes, extreme care is called for and the absolute safest way is indeed to open up the phone and remove the camera first.
Naturally that adds a lot of effort and the risk of breaking something else into the mix, but as far as protecting the integrity of the camera, that's the correct procedure to follow.
Ultimately it's a cost/benefit tradeoff analysis each person will have to do for themselves.
さんによる
さんによる
@dadibrokeit not easy if cracked, not easy if shattered. Stupid, they need a screw off lens
さんによる
コメントを追加
回答を追加する
Olav Johnsen さん、ありがとうございました!
統計データ:
過去 24時間: 26
過去 7 日: 155
過去 30 日: 840
今までの合計 83,031
