メインコンテンツにスキップ
Repair guides and disassembly information for the Samsung Galaxy A51 Android smartphone. Released in January of 2020.
20回答 すべてを表示
How to save the data with a broken screen Samsung A51?
So I got the following problem, the phone got dropped from the 3rd floor and the screen is completely mashed. The phone still boots and is online, you can also use a mouse or keyboard to put in the passcode.
Now I want to save the data off the phone before I do any taking apart or such. How can I achieve that? I tried using the keyboard to put in the passcode and then plugging it in to my PC, however it needs to allow the PC before I am able to access the data.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
you can use a hub to mirror the image of the screen to a tv or monitor via hdmi
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
You cant right, since A series doent support video output over HDMI. A series has no Dex support
さんによる
コメントを追加
You need to enable usb debugging. Use your mouse to,
Go into settings then look for software information then find the build number.
Click on the build number 7 times and a pop up should say you are now a developer.
Click back into setting and click on developer options, scroll down to usb debugging and enable it. Go back to the Home Screen and try connecting your computer again.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Well, I would do that, but I can't see anything on the screen so that is not possible, if it was I could also do it while connecting it to a PC.
さんによる
So how do you put the passcode in if you can’t see anything? Try running smart switch and connect the phone. You might have to allow access which you can’t do. Last resort is Google adb android data transfer. Ball ache but it might help. Is it not backed up to your Google account online?
さんによる
コメントを追加
回答を追加する
JSE さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 942
