Requesting iPad 7 WiFi NAND Area Diode Mode Readings
Hello Everyone!
Please help me with iPad 7 WiFi NAND area diode mode readings.
Thanks!
On the chance that you still haven’t found this yet, I use this website for Diode mode readings often, but it’s only really got connectors. So not NAND. But I have a spare known good of this model, I will see what I can get for you in the morning,
このアンサーは役に立ちましたか?
Thats amazing!
I was trying to find a schematic for them but could only find payed ones that didn't come with a board view files and only schematics
il let them know you have solution
@flannelist thanks a lot, it will be very helpful to get readings from good board. @hellomacos
Hi
Do you have a schematic for it?
If you do that schematics tell you the size
Or
If you want to post some photos using this amazing guide
I could use the photos the photos to try and tell what size they are
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
I don't have schematics. I want to check on logic board if NAND points are properly connected to other areas. hence I want to know diode mode readings for NAND area.
@hellomacos I don’t think it’s about the diode but checking for a short on a circuit in diode mode on your multimeter check on here for the how etc
I see
I would check places like the badcaps forums for schematics as they’re a few for a verity of models on there on there
When you said measurements I thing you meant measurements like 0402 0201….
Il have a look my self and see what I can find
Also what is the Board number you are working on?
I just realised that
I though they were on about components sizes because he said measurements in the original post
Thanks for letting me know:-)
@hellomacos my bad, sorry
過去 24時間: 1
過去 7 日: 2
過去 30 日: 18
今までの合計 744
