メインコンテンツにスキップ
The 2018 version of the Samsung Galaxy A7 smartphone released in October 2018.
53回答 すべてを表示
Dropped my phone screen is black but the notification are still coming
Hy. So my phone split of my hand and hit the floor it was about 50 cm after the screen was black i could hear the notification but the screen was black my phone has glass protector the screen is not DAMAGED pls help.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi,
Just because the screen appears not to be damaged doesn't mean that it didn't suffer any internal damage that is not visible e.g broken connection in the display panel.
As a DIY repair all you can do is to temporarily replace the display assembly and check if it works or not. This is to find out if the problem is in the display or on the systemboard.
Here's the ifixit Samsung Galaxy A7 (2018) Display Assembly Replacement guide that will help.
Search online for Galaxy A7 (2018) display assembly to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You could try to force restart the phone by holding the volume down and power button until it restarts. You should feel a vibration when it is turning back on.
But most likely the screen is damaged. The glass may not be cracked but the OLED underneath the glass probably is. So a screen replacement would most likely be the solution to your problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sᴘᴏʀᴛ ᴄᴇɴᴛᴇʀ さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 53
今までの合計 1,437
