メインコンテンツにスキップ
Bose's consumer range of active noise-cancelling headphones are called "QuietComfort".
21回答 すべてを表示
Right side no audio with ANC on
Symptoms: With ANC on there is no sound in the right earphone.
It also seems like right side audio may be slightly quieter with ANC off, but full sound is delivered.
Tried: Replace battery
Loose connection? Bad motherboard?
These things are unnecessarily annoying to tear down.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi
Unfortunately you might not be far off the answer
It could be a bad board ,loose connection or a torn cable
Have you also looked at the battery connections to check for corrosion?
What I would do is take them apart and check everything for any damage or defects
If you can’t find any I would replace the main board and work from there
Hopefully this helps
Any questions please ask
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Trevor Miles さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 82
