メインコンテンツにスキップ
Repair guides and troubleshooting for dishwashers made by Electrolux.
8回答 すべてを表示
Help! Used Pipe Drainer into Dishwasher.
Hello, I need some help please. My dishwasher was blocked so I had the 'brilliant' idea to put pipe drainer into it. Obviously it didn't help, we had to call an engineer which came after 15 days to fix it. The chemical stayed in the dishwasher for 15 days, after the engineer fixed it, I run 4x 70 degree cycles but I'm still worried it all the chemical had gone away. Please don't judge me, I was so silly to do that. What shall I do now, will the dishwasher be still contaminated? How can I make sure is cleaned and will it be ever safe to use again? Thanks a lot for any advise.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Just run it through another cycle or two, with soap. Whatever soap you normally use. The soap will help clear any residue from the machine. And repeated cycles will flush that residue from the machine. Should be fine.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you for your reply!
さんによる
コメントを追加
回答を追加する
Laura De Min さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 39
