メインコンテンツにスキップ
Nintendo Switchは、ドッキングステーションを介してテレビで遊んだり、外出先で遊んだりできる携帯型ゲーム機です。2017年3月3日に発売されました。
706回答 すべてを表示
Switch not connecting to TV - Years long problem
Hello. Kinda new here.
So my nintendo switch has had an ongoing problem for nearly 4 years, which is about as long as ive actually had it. It doesn’t connect to the TV whatsoever.
Ive tried 3 TVs and a kinda older, but still great monitor, and nothing. However, when it does actually show up, it only lasts for a minute then completely stops.
A few days ago, i tried it out again with my main TV and the monitor again, and it once again only showed up for a few seconds, but i accidentally wiggled the cable and it showed up a bit longer.
I genuinely thought it was a problem with my dock, so i got a 3rd party one (CharJenPro) and ive gotten the exact same results. (I accidentally misplaced my og dock and i have no idea where its at, so the 3rd party one is the one im kinda forced to use rn)
Both dock lights show up, they work, but theres nothing to the display and no sound either. I have tried nearly EVERY solution and nothing has worked, and if it did, it only lasted a few minutes.
Plugging it in the official nintendo way, using a dab of alcohol on the ports so theyre clean, using different HDMI cables (i tried all of the ones i own, 4 , and same thing), using different ports on the same display, and recently, using compressed air. Nothing.
Im now convinced its not the dock’s fault anymore. I think it could be the USB-C port being faulty. I checked with a light to see if anything was bent, and while i didn’t see anything, i could be missing very small stuff.
What do you guys think? Getting a new system is my very last resort since i dont have money to just buy a new one rn. Much rather have just a replacement port or something.
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
Bought the switch a few years ago for my grandkids, after about the first year it stopped connecting to the tv. It worked great just not connecting to the tv, so bought a knock off dock… still nothing. Frustrated because we’re stuck playing using the handheld to play rather than being able to share the fun. Any suggestions are appreciated!
さんによる
my Switch, after a couple years developed the same problem. I suspect it's the USB-C connector on the Switch as well.
Weirdly, it will output if I plug in a cheap USB-C hub that also does power delivery and HDMI out. But it doesn't work with three different official nintendo docks.
さんによる
コメントを追加
2件の回答
ベストアンサー
what this "accidentally wiggled the cable and it showed up a bit longer" leads me to believe that this is not your Switch but the USB-C connector. Remember that this is different than your common USB connector. It has solder points on the bottom. I would try to find somebody that can do the soldering and re-solder the connector. All this will of course depend on where you reside etc. so an online search for some board level repair person may work for you.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Thank you! I knew it, but i needed to make sure it wasnt the motherboard or something.
Ive heard its pretty difficult to replace the port by yourself, so i’ll definitely take it to a shop or send it in someplace
Thank you so much once again!
さんによる
コメントを追加
This sounds like it could be either an issue with the port or the board (but leading heavily towards the port). Especially if it is working normally otherwise. You don’t mention any issues with it working properly when it is not docked or connected to external video.
You will need to do some soldering to replace the USB C port, however since it is hard wired onto the board itself. You can likely also find a shop, who performs these sorts of repairs.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you very much! Yeah it works just fine in tabletop and handheld, and the problems start when its docked, so its definitely the port.
Thank you again!
さんによる
コメントを追加
回答を追加する
what さん、ありがとうございました!
統計データ:
過去 24時間: 8
過去 7 日: 38
過去 30 日: 272
今までの合計 17,097
